M800 AT for Pressure Sensor
I see user manuals with the following wording and understand that the addition of the 1k pull-up to 5v on the AT pins will influence the signal and may require a custom sensor calibration.
Can you advise what min/max pressure sensor impedance is acceptable for use with an AT input pin on the M800 ECU?
I'm hoping to use the RaceGrade 150 PSi gauge sensor which is quoted as having a < 100 Ohm output impedance.
Some voltage output sensors can be used to connect to the analogue
temperature inputs if they can drive the pull-up resistor without causing
an error in their reading (e.g. MoTeC Thermocouple Amplifier).
