TP2 Throttle Limit Calibration
I'm setting up DBW on an M800 and am unsure how to calibrate the TP2 sensor when it's not a full range 0-100% sensor.
The throttle servo is a Mikuni unit similar to that used in the Mitsubishi Evo X. The tracking sensor only operates from 0 to approx. 54% of the range.
TP has an output of 0.480 (0%) to 4.532v (100%)
TP2 has an output of 2.494 (0%) to 4.654v (53.8%)
How should the Throttle Position 2 Open voltage be calibrated so the M800 know to ignore the tracking sensor once it reaches its limit.
This is analogues with Servo Bank 1 Position Sensor Tracking Limit in M1 GP packages.
