LATE TYPE LS3
LATE TYPE LS3
Postby GWRMOTORSPORT on Wed Dec 30, 2020 10:46 pm
Just wondered is it possible to run the later type LS3 engine, 60-2 ref, 4 tooth sync on M800, thanks
GWRMOTORSPORT
Re: LATE TYPE LS3
Postby Sean on Thu Dec 31, 2020 8:34 am
Mode 17 should be it. I have 2 files from LS3 both running that. When you say later type, what year?
Sean
Re: LATE TYPE LS3
Postby Stephen Dean on Mon Jan 04, 2021 9:10 am
Correct, Mode 17, Crank trigger to B1 and Cam to B2 and a starting CRiP of 80.
Re: LATE TYPE LS3
Postby GWRMOTORSPORT on Tue Jan 05, 2021 7:17 am
Hi Sean, thats great news, could you PM me to discuss further, thanks to Stephen for additional info too,
Cheers Steve
GWRMOTORSPORT
Re: LATE TYPE LS3
Postby super7 on Wed Jan 06, 2021 9:03 am
What is the difference between Ls2 and Ls3?
A friend of mine is starting up a corvette"'Im working on GM LS2 based motor with the old infamous 24x GM Gen3 trigger wheel. I can not get the Motec M800 ECU to synchronize. Does anyone know of any tricks or caveats with the Motec?
I am likely to resort to mode 2 (multi tooth) and hope the rising edge of the cam signal does not wander too much with load and rpm.
With ref sync mode 23 (GM Gen 3) I tried all trigger edge combinations only if the trigger mode is worth anything the trigger edge should not matter as the ECU should monitor both edges to have any benefit of the uneven timing of the rising edge and the even timing of the falling edge. "
super7
Re: LATE TYPE LS3
Postby Stephen Dean on Wed Jan 06, 2021 9:11 am
With the 24 tooth setup (mode 23), you run the crank signal spliced to the Ref and Sync pins, and the Cam signal into Digital 1 (there is no setup needed for Digital 1). The base CRiP is 455 and use Hall/Fall for the Ref and Hall/Rise for the Sync setup, with a 0.5 filter for both.
Re: LATE TYPE LS3
Postby Sean on Wed Jan 06, 2021 10:09 pm
super7 wrote:What is the difference between Ls2 and Ls3?
One important difference is that the crank sensors themselves are different and not interchangeable, even though they physically bolt in. LS1/2 24 tooth is a black sensor, LS3/7 is grey.
Sean
Re: LATE TYPE LS3
Postby super7 on Thu Jan 07, 2021 5:04 am
SDean wrote:Hi,
Hi Stephen
If you have a start map, you can email it to super7@hakmark.net
Regards Nils-Erik
super7
