M600 TC Speedometer Question
Noble M12
Current config. includes front wheel speed sensor (12v Hall effect) directly wired to Race Technology Dash2 to display road speed.
Planned changes include fitting M600.
If i rewire front wheel speed sensor to the M600 TC reference input, can that signal also be used to display road speed on the Dash2 via the CAN stream? Or is it only for single use in the TC system?
Or can i feed the sensor output to both Dash2 and M600?
If either solution will work it'll save me having to have the other front hub drilled for another wheel speed sensor.
