Local grounding question
Is it ok to locally ground items such as fuel pump and other 12v devices ? Or should a seperate ground wire be run all the way back and star pointed?
Also, this may be a dumb question but I have a few devices (flex fuel sensor, etc) what are asking for 12v power instead of 5 or 8v.. Where should I pull this when using a PDM? I was thinking all of my 12v supply would be coming out of that, but I am not sure where to pull this 12v for low current sensors. I still plan on using a key, would it be bad practice to pull from the switched side of the ignition switch (using this to trigger the PDM / ECU)
