M600 Settings - 2JZ-GTE OEM Idle Air Control Valve
Postby MaccaMcc on Thu Jun 11, 2020 2:57 pm
Hey guys,
I'm in the process of changing some of the setup on my car. Currently the IACV stepper is controlled by the stock ECU while the M600 manages fuel and igntion. Dont ask - that's how it was setup when I bought the car.
I want the M600 to control the IACV to try and improve the warmup/idle/low load characteristics.
Does anyone have any experience using this stepper / ecu combo and could give me a starting point for the settings in idle control, Aux out - idle stepper and for setting the hi/low values?
Cheers,
Dave
MaccaMcc
Re: M600 Settings - 2JZ-GTE OEM Idle Air Control Valve
Postby Blu302 on Sat Jul 11, 2020 10:59 pm
I would suggest you convert it to a 2 wire valve like this and use basic pwm like the fords etc.
https://www.golebysparts.com.au/products/1jz-syltech-2-wire-sensor-idle-air-control-valve
The 2-wire IACV's are easy to setup.
I was using 30-50% on my 302W V8 for hot/cold starts.
25-30% was the hot idle range for 1100rpm
Blu302
Blu302
