ignition module Zetec
Postby era30 on Fri Mar 20, 2020 10:01 am
Which ignition module shall I use on Zetec BT with OEM coil? I have a Bosch 0 227 100 203 but not sure it is the correct
one.
thanks for helping
ERA 30
era30
Re: ignition module Zetec
Postby AdamW on Fri Mar 20, 2020 3:03 pm
The 0227100203 will do the zetec coil fine.
Motorsport Electronics Ltd.
AdamW
Postby super7 on Sat Mar 21, 2020 8:42 pm
Hi.
I drove 0 227 100 200 for many years and it worked well
Sincerely, Nils-Erik
super7
Postby era30 on Mon Mar 23, 2020 7:12 am
Many thanks for a quick reply.
I am a absolute novice concerning Motec products so maybe I have silly questions, my present ECU is a Alpha Pro 5
which is quite straight forward. Now I have bought a M400 serial # 13001-05611 and loom S/N 589 M400 to Ford Siesta
High speed.
On drawing M38 there are 3 coils but Zetec got 2-can I use only 1 and 3? My tacho is an ETB where I connect it and
gear shift light and fuel pressure pump?
Regards
Hans
hasse26r@gmail.com
era30
Postby super7 on Tue Mar 24, 2020 4:17 am
Hi.
Look at drawing M29 # 41200 instead.
I used Aux1 for Tacho
Aux3 for fuel pump
Aux4 shift light
super7
Postby era30 on Tue Mar 24, 2020 6:11 am
Thank you Nils-Erik,
Tack skall du ha
Med vänlig hälsning
Hasse
era30
Postby era30 on Wed Apr 29, 2020 8:49 pm
super7 wrote:Hi.
Hej,
Jag strular med min 400 men får det inte att funka med en del inställningar. T.ex.inst.av vevgivaren,sv.hjulet
har 34 hål och 2 missing men vilket värde skall man sätta? Som jag har uppfattat har du en Zetec BT.
Skulle uppskatta om du kunde hjälpa mej.Vad jag vet finns det inget program för denna motor.
Jag bor i Helsingborg 0706906320 hasse26r@gmail.com
Med vänlig hälsning
Hasse
era30
