M400 for sale serial 13001-17459
Postby TonyS on Fri Jan 17, 2020 9:50 am
Hi
The above ECU is for sale and I would like to know which options are enabled please?
Regards
Tony
TonyS
Re: M400 for sale serial 13001-17459
Postby Stephen Dean on Mon Jan 20, 2020 9:29 am
That ECU has the following functions.
M400 # 17459
Options
24110:ENABLE
24105:ADVFUNC
24101:512K LOGGING
24103:1M LOGGING
Postby TonyS on Thu Jan 30, 2020 3:58 am
SDean wrote:Hi,
M400 # 17459
Options
24110:ENABLE
24105:ADVFUNC
24101:512K LOGGING
24103:1M LOGGING
Thanks for the reply. Could you elaborate on part number 24110 (I can't find it anywhere). Am I correct in assuming then that it does not have the Lambda function enabled?
Many thanks
Tony
TonyS
Postby David Ferguson on Thu Jan 30, 2020 4:06 am
Enable means that is works at all.
They ship the units without this so they are essentially worthless if stolen or lost. If you purchase a produce from an authorised dealer, it will be at a minimum enabled.
Postby TonyS on Thu Jan 30, 2020 5:29 am
Thanks for that. So it's another £400 GBP for the Lambda upgrade. I'll stick with my M84... ;)
Cheers
Tony
TonyS
