M800 VR Speed Input
M800 VR Speed Input
Postby Vlad on Thu Oct 03, 2019 8:04 pm
Would a trick like wiring switched +12V to the +Pin on 2 wire vr sensor, and the - wire of the sensor to a DIG input with a pull down resistor to 0v work on hundres series ecu ? I'm asking because i saw in another post that this can be done in the M1 Dig inputs. Thak you, Vlad :)
Vlad Pescaru
Vlad
Re: M800 VR Speed Input
Postby Stephen Dean on Fri Oct 04, 2019 10:00 am
Hi Vlad,
The setup for the M1 came from the Mx00 ECU's, so it does work.
