motorcycle starter button with clutch in
Postby nappinj on Tue May 07, 2019 11:31 am
I have my starter button wired to input and clutch wired to input and starter solenoid to output. is there a way to make it has to see clutch in before starter input would turn on output? m880
nappinj
Re: motorcycle starter button with clutch in
Postby David Ferguson on Tue May 07, 2019 4:04 pm
Use an aux output table, set the X axis to the Clutch Switch Input, and the Y Axis to the Starter Switch Input, then fill in the table with the conditions when you want the output to be driven.
Postby nappinj on Sat May 11, 2019 8:55 am
thanks but inputs are not on options
nappinj
Postby nappinj on Sun May 12, 2019 10:39 am
I got at5 to work as a button thought. I had to put .4 low and .5 hi to make it work
nappinj
