Lambda sensor reading problem
Posted: Fri Apr 26, 2019 9:58 am
Hello all,
I have a m400 ECU running a 07 cbr600rr.
This is the second year we run this engine.
I am having trouble with the lambda sensor. Basically it's always reading rich. No matter what I do to the tune, it's it's always fluctuating around 0.8. I can cut fuel with overall trim all the way to 50% and it still shows rich.
I thought the sensor was bad, so I bought a new one. Same LSU 4.9. I checked heater voltage and all the grounds, and it seems fine. I try air calibration again and got the same value ( around 1200).
What am I do wrong? Is this a wiring issues, or a fundamentals issue. (Timing, fuel timing).
I tried running the car and decreasing fuel pressure at the rail, to rule out stuck injector. But it kept reading around
0.8
Any help is greatly appreciated!
0.8
