Lambda sensor reading problem
Postby apiazza2010 on Fri Apr 26, 2019 9:58 am
Hello all,
I have a m400 ECU running a 07 cbr600rr.
This is the second year we run this engine.
I am having trouble with the lambda sensor. Basically it's always reading rich. No matter what I do to the tune, it's it's always fluctuating around 0.8. I can cut fuel with overall trim all the way to 50% and it still shows rich.
I thought the sensor was bad, so I bought a new one. Same LSU 4.9. I checked heater voltage and all the grounds, and it seems fine. I try air calibration again and got the same value ( around 1200).
What am I do wrong? Is this a wiring issues, or a fundamentals issue. (Timing, fuel timing).
I tried running the car and decreasing fuel pressure at the rail, to rule out stuck injector. But it kept reading around
0.8
Any help is greatly appreciated! :D
apiazza2010
Re: Lambda sensor reading problem
Postby apiazza2010 on Mon Apr 29, 2019 1:21 am
Quick update for everyone. I was still not able to find the cause of the problem. I have looked at the logged data from the test session and can see what appears to be an offset.
I need to double check if the grounding or the 5/8v sensor wire are interfering with the lambda.
Fluctuations look correct, but everything is extremely rich. Changing the Overall Trim to even -30% does not change anything in the logs. Even tho i can hear the engine rev dramatically faster making me think it is going lean.
apiazza2010
Postby David Ferguson on Mon Apr 29, 2019 3:46 am
Have you looked at the spark plugs? Any chance you have an injector stuck open? Anything on the Diagnostics screen?
BTW - your calibration number of 1200 seems high -- we would expect closer to 1000. Perhaps you have a bad connection / corrosion on one of the Lambda Sensor connections.
Users browsing this forum: Google Adsense [Bot] and 12 guests
