transmit an M800 file to an M600 ECU
PostPosted: Thu Mar 21, 2019 12:49 pm
by yhubaldiaz
hello friend, Iam trying to send an M800 file to an M600 ecu but it will not let me. if someone could help me solve it,it would be excellent,thank you.
it get this when I try to file the file:
this file required the ecu to have the following capabilities or options
_unused ignition outputs (not available in M400 &M600
_unused injector outputs (not available in M400 & M600
"THIS FILE CANNOT BE SENT TO THIS ECU"
Re: transmit an M800 file to an M600 ECU
PostPosted: Thu Mar 21, 2019 2:29 pm
by Stephen Dean
You have functions allocated in the M800 file to outputs that are not available for use in the M600, if you remove these functions from the file to suit the M600 pin availability then you will be able to send the file into the M600.
PostPosted: Fri Mar 22, 2019 12:18 pm
by yhubaldiaz
thanks stephen but tell me, how do I eliminate these function to adapt them to the ECU M600 or rather I do not know where these functions are enabled, because I have compared the 2 files of M800 and M600 and they seem the same to me.
PostPosted: Fri Mar 22, 2019 12:30 pm
by Stephen Dean
Post the file that you want in the M600 and I'll have a look at it for you.
PostPosted: Sat Mar 23, 2019 4:40 am
by yhubaldiaz
EVO_8_Startup.e35
(72 KiB) Downloaded 1193 times
this file that is from M800 that I want to send an ecu M600
PostPosted: Sat Mar 23, 2019 5:17 am
by David Ferguson
You need to change Adjust->Injector Output Functions-> Injector Out 7" (and 8) so the Function is "Off". The M600 only has 6 injector outputs. Note -- you will probably need to change the fuel pump control (which was using Injector Out 8) to another suitable output (for example, you have plenty of unused Auxilary Outputs (the M600 has all 8).
PostPosted: Sun Mar 24, 2019 2:54 pm
by yhubaldiaz
thank you very much David Im going to do
saludos.
