transmit an M800 file to an M600 ECU
Postby yhubaldiaz on Thu Mar 21, 2019 12:49 pm
hello friend, Iam trying to send an M800 file to an M600 ecu but it will not let me. if someone could help me solve it,it would be excellent,thank you.
it get this when I try to file the file:
this file required the ecu to have the following capabilities or options
_unused ignition outputs (not available in M400 &M600
_unused injector outputs (not available in M400 & M600
"THIS FILE CANNOT BE SENT TO THIS ECU"
yhubaldiaz
Re: transmit an M800 file to an M600 ECU
Postby Stephen Dean on Thu Mar 21, 2019 2:29 pm
You have functions allocated in the M800 file to outputs that are not available for use in the M600, if you remove these functions from the file to suit the M600 pin availability then you will be able to send the file into the M600.
Postby yhubaldiaz on Fri Mar 22, 2019 12:18 pm
thanks stephen but tell me, how do I eliminate these function to adapt them to the ECU M600 or rather I do not know where these functions are enabled, because I have compared the 2 files of M800 and M600 and they seem the same to me.
yhubaldiaz
Postby Stephen Dean on Fri Mar 22, 2019 12:30 pm
Post the file that you want in the M600 and I'll have a look at it for you.
Postby yhubaldiaz on Sat Mar 23, 2019 4:40 am
EVO_8_Startup.e35
(72 KiB) Downloaded 1194 times
this file that is from M800 that I want to send an ecu M600
yhubaldiaz
Postby David Ferguson on Sat Mar 23, 2019 5:17 am
You need to change Adjust->Injector Output Functions-> Injector Out 7" (and 8) so the Function is "Off". The M600 only has 6 injector outputs. Note -- you will probably need to change the fuel pump control (which was using Injector Out 8) to another suitable output (for example, you have plenty of unused Auxilary Outputs (the M600 has all 8).
Postby yhubaldiaz on Sun Mar 24, 2019 2:54 pm
thank you very much David Im going to do
saludos.
yhubaldiaz
Users browsing this forum: No registered users and 73 guests
