M800 back-up features
I would like to confirm if there is an back-up feature at M hundred series ECU. Into OEM ECU, when lost cam sensor signal, the engine still run using only crank speed, migrating from sequential ignition firing to wasted spark. Same approach for fuel (sequential -> batch).
I would like to confirm if there is this kind of feature into MoTec (automatic Ref/Sync on-fly adjustment in case of sensor failure).
I would like to build an robust setup following OEM protection, so, only will stop the engine if lost crank speed signal:
Two routines that I would like to add:
1.Lost cam signal -> Wasted spark, but running full performance
2.Lost temperature sensors signal -> Safe mode system, limited output
There is any routine setup like this into M Hundred series?
Thank you in advance,
Matheus
Matheus
