m400 EFI TUNE with big bore
Hi guys,
I'm currently running a KTM 525 EXC engine in an FSAE car. It is a single cylinder with a stock displacement of 510cc and has been converted from carburettor to EFI through a 12-2 trigger wheel and a motec m400 ecu. It has been upgraded to 540cc through a big bore. Prior to upgrading the bore, there was a tune done for it and it ran like a dream. After the big bore, i increased the fuel through the overall trim of about 15% and it runs and revs but when driving there seems to be a lack of power up top and it doesn't seem to rev out higher than 7k rpm. There also seems to be a throttle delay before and after throttle is opened and closed. I've tried playing around a little with the fuel and timing maps but can't seem to rectify the issue. I was told by the dyno shop that a big bore shouldn't really affect the tune that much, just an increase in fuel is needed.
Any help and advice is greatly appreciated. Thanks!
