battery voltage question
my M800 wont allow the engine to start once the battery supply voltage drops below about 11V
with my installation, if it happens to need extended cranking because its really cold or whatever, and the battery volts drop to under 11V and it wont start , despite still cranking just fine. as soon as i add a jump pack, it fires immediately
battery passes all sort of load tests and the voltage supplied to the motec plug is within 0.2V of the battery post at crank
the specs indicate the Motec should be able to handle 6-20V
i cant find any reference to this issue on this forum or on a general Motec Google search "m800 minimum voltage"
any clues appreciated
thanks
thanks
