CAN based Digital Input functions
On the MXXX series I can see that you can configure the SW In 1-6 functions to use a CAN based input rather than the associated AT physical input.
If using the CAN based function, does this free up the underlying AT input to be used once again as a regular AT input?
EG, if I have a switch hooked up to one of the analogue inputs on a E816 or DBW4, can I use this switch to provide the logic for setting SW In 1 to Ground Speed Limit active, and still use the associated AT1 as say gearbox oil temp on a User channel?
Cheers,
Ben
Cheers,
Ben
