TCMUX & M800
I have searched the previous posts and didn't find anything completely answering my question(s). I have an M800 and am considering using traction control. However, I am not too clear on how to achieve this.
It would seem that all I need to do is use the 4 digital inputs configured as wheel speed sensors (in Hall format using mag converters). In the m800 sw (V3.5) adjust -> sensor setup -> input setup -> pin assignments -> speed in the default channels are LD, RD, LG & RG. Is this all that is required ? The only down side of this is that you use all of your 4 dig inputs.
The other option seems to use the TCMUX. According to the catalog: The traction control multiplexer takes 4 individual wheel speed signals, and turns them into one coded signal for an ECU to read as driven speed (wheels that have power), undriven speed (rolling wheels) and slip (% difference between driven and undriven wheels.) In the M800 s/w there are 3 parameters TCM Rolling, TCM Ldrive and TCM Rdrive. What pin is the output of the TCM assigned to (dwg A01 only makes reference to the M4 and M8 ECUs, if I had to guess I'd say B8)
Will either of these approaches work ?
