Magnetic / VR sensor for wheel speed
I am looking for a magnetic sensor to use for wheel speeds with an M880 - the car I am putting them on (Sierra Cosworth) has an older Teves ABS system with ATE VR sensors which a) are almost impossible to get these days and b) are a pain with the wiring so I am looking at alternatives.
The trigger discs in the hubs have a fairly small tooth profile - about 1.5mm tooth width, 3-4mm pitch and 2mm depth (see attached image) which I think rules out using a hall effect sensor (unless someone can suggest one that will work with this small tooth profile).
I see there is the 52002 listed on the Motec site however there is no specs document for it to check the required tooth profile - does anyone know what they are? The 2 other magnetic sensors list a tooth gap of greater than 10mm which rules them out in this application.
I have also seen this type of magnetic sensor - https://au.rs-online.com/web/p/magnetic ... s/0304172/ which has an integrated IC to output a digital signal - could this be used instead, also negating the requirement for a DMCD?
