Magnetic / VR sensor for wheel speed
Postby bdinnerv on Tue Sep 25, 2018 7:13 pm
I am looking for a magnetic sensor to use for wheel speeds with an M880 - the car I am putting them on (Sierra Cosworth) has an older Teves ABS system with ATE VR sensors which a) are almost impossible to get these days and b) are a pain with the wiring so I am looking at alternatives.
The trigger discs in the hubs have a fairly small tooth profile - about 1.5mm tooth width, 3-4mm pitch and 2mm depth (see attached image) which I think rules out using a hall effect sensor (unless someone can suggest one that will work with this small tooth profile).
I see there is the 52002 listed on the Motec site however there is no specs document for it to check the required tooth profile - does anyone know what they are? The 2 other magnetic sensors list a tooth gap of greater than 10mm which rules them out in this application.
I have also seen this type of magnetic sensor - https://au.rs-online.com/web/p/magnetic ... s/0304172/ which has an integrated IC to output a digital signal - could this be used instead, also negating the requirement for a DMCD?
Wheel speed pickups
Its not the speed that kills, its the sudden stop at the end
bdinnerv
Re: Magnetic / VR sensor for wheel speed
Postby moylee19 on Tue Sep 25, 2018 10:03 pm
why not grind or machine some teeth out to give a larger spacing, thus allowing the use of a hall effect or any mag sensor.
Motec CDL3 - M130 -LTCD - PDM15 - Keypad
Suzuki GTi IPRA Car
moylee19
Postby bdinnerv on Tue Sep 25, 2018 10:47 pm
moylee19 wrote:why not grind or machine some teeth out to give a larger spacing, thus allowing the use of a hall effect or any mag sensor.
That is my last alternative, am trying to see if there is a sensor I can use first before removing metal - these parts are getting harder and harder to find for a car that was pretty much only sold in the UK in pretty limited numbers.
bdinnerv
Postby stevieturbo on Wed Sep 26, 2018 1:09 am
Lots of OEM use fine tooth multi tooth wheels for ABS...probably as handy just to find another OEM sensor ?
ie...sensor and ring ? just adapt the sensor ?
https://www.ebay.co.uk/itm/BMW-3-SERIES ... 2371862273
Postby Scott@FP on Fri Sep 28, 2018 5:02 am
Keep in mind for wheel speed you want to use a zero RPM sensor if you can, not one that needs XXX RPM to start working.
For hall effect with small teeth, try this one (or a similar modern one), it will handle small teeth-
https://www.mouser.com/ProductDetail/785-SNDH-T4L-G01
Postby bdinnerv on Fri Oct 12, 2018 8:48 am
Scott@FP wrote:For hall effect with small teeth, try this one (or a similar modern one), it will handle small teeth-
Thanks, the stats seem to be pretty close to what I need so will give one of those a go.
bdinnerv
Users browsing this forum: Bing [Bot] and 5 guests
