m800 + dbw4 evo 9 idle + ADC controler
hello everyone, i just installed dbw4 module on my evo 9 with m800 pnp, im having issues with idle, at first idle was to high no mater what i do, i ended up recalibrating throttle not like mentioned in manual
0.5 mm gauge), but completely closed, now my idle is hunting, and i cant stabilize it, i removed idle control from auxiliary outputs since i don't have idle control valve any more, i set throttle translation table under drive by wire, car drives fine, but doesnt idle correctly
another question related to dbw, since i dont have tps input any more whit it wa sshared with mitsubishi adc controller, how can i make it to work again, is there a way to simulate output of tps to adc using one of pwm outputs, or i can just tap in to one of accelerator pedal position sensors signal wire, also if im gonna get motec mdc will it work without phisical tps input or im gonna have same problem,
Thx
Thx
