BMW S54 map file request M600
Postby aniesigh on Sat Feb 24, 2018 11:56 am
Hi, I have searched on here and found 1 file but as it was posted up as the user was having issues I’d rather not really trust it,
So does anyone have a map file they would be willing to share? I’m running Vanos (switched to ground) and the stock DbW arrangement (although a non-bmw pedal)
Engine and ecu setup came in an Offroad racer I bought, and was fitted apps 10 years ago and has been mapped again since (previous owner had it done)
It seems hard to start from cold, and very rich on warm up, fouls plugs for fun.
Would be interested to see other people’s files for comparison, also to compare Vanos config.
Alternatively if someone doesn’t want to share their file but fancies taking a look at mine then I can post it up.
Cheers!
aniesigh
Re: BMW S54 map file request M600
Postby David Ferguson on Sat Feb 24, 2018 12:33 pm
Can't offer a config for that engine. Do you have logging enabled in the M600? Wideband Lambda fitted?
If so, could you capture a log of the cold startup and post that? Normally the logged data will include a copy of the config, so you may not need to post that separately.
What have you tried to improve the starting?
