Mx00 Options enabled check requests
Postby Tunedgether on Sun Dec 31, 2017 7:34 pm
I would like to check options enabled of M600 serial 02272. What has upgraded?
Regards,
Paisan R.
Tunedgether
Re: check M600 options enabled
Postby Stephen Dean on Sun Dec 31, 2017 7:51 pm
HI,
That M600 has the following options enabled.
M600 # 2272
Options
26110:ENABLE
26105:ADVFUNC
26102:SINGLE LAMBDA
26103:DUAL LAMBDA
26112:DRIVE BY WIRE
26116:CAM CTRL
Postby Tunedgether on Sun Jul 01, 2018 7:28 am
I would like to check options enabled of M400 serial 03074. What has upgraded?
Regards,
Paisan R.
Tunedgether
Postby Stephen Dean on Mon Jul 02, 2018 10:05 am
That M400 has the following functions enabled;
512K Logging
Single Lambda
Postby Tunedgether on Mon Oct 29, 2018 5:08 am
Please check options enabled of M800 serial 11292. What has upgraded?
Regards,
Paisan R.
Tunedgether
Postby Stephen Dean on Mon Oct 29, 2018 9:44 am
The following function are enabled on that M800.
M800 # 11292
Options
28105:ADV FUNC
28101:1M LOGGING
28112:DRIVE BY WIRE
28116:CAM CTRL
Postby ralfexlv on Mon Jan 14, 2019 6:31 pm
Please check options enabled of M800 serial 9636. What has upgraded?
Regards,
Ralfs
ralfexlv
Postby Stephen Dean on Tue Jan 15, 2019 8:53 am
Hi Ralfs,
That M800 has the following enables.
M800 # 9636
Options
28118:OEM ENABLE
28105:ADV FUNC
28101:1M LOGGING
28102:SINGLE LAMBDA
28116:CAM CTRL
Postby Tunedgether on Thu May 30, 2019 7:08 am
Please check options enabled of M400 serial 17498. What has upgraded?
Regards,
Paisan R
Tunedgether
Postby Stephen Dean on Thu May 30, 2019 9:02 am
That M400 has the following enables;
M400 # 17498
Options
24110:ENABLE
24101:512K LOGGING
24102:SINGLE LAMBDA
24112:DRIVE BY WIRE
