Fuel pump PWM control
Posted: Thu Aug 31, 2017 7:54 pm
as I'd like to reduce the fuel pump noise and heat at idle/low load/rpm, I'd like to add a SSR between ecu and fuel pump.
Problem is that I have only one output left, the one I'm currently using as 101 "fuel pump" and, if I read correctly, using 124 / 138 (fuel pump control) or an Aux Table will lead you to loose the Delay/Priming option:
is that correct?
How to solve this?
is that correct?
How to solve this?
