David Ferguson wrote:Do you have the Race Technology ECU Interface? -- I believe you will need this with your Dash4 -- as the only serial protocol it receives is the Race Technology protocol -- they use the ECU interface to bridge to either CAN or Serial communications. The Dash4Pro also has an optional direct CAN interface -- any chance your dash has that option? BTW it cost more than the external ECU interface listed below.
I would suggest you use the CAN interface instead of the serial if you are going to be acquiring a Race Technology ECU Interface. They cost the same
Pre-programmed interface:
http://race-technology.com/gb/racing/pr ... interfacesProgrammable CAN Interface:
http://race-technology.com/gb/racing/pr ... -interface
Thank you for your reply, David. I bought the following products:
DL1CLUB advanced GPS data logger
DL1 CLUB 20Hz GPS upgrade
DL1 CLUB internal ECU serial interface
GoPro video import licence
DASH4PRO display unit with LCD screen
USB Programming Lead
In fact, I am not sure if I set the ECU properly.
Adjust > General Setup > Communications > RS232 Telemetry Setup
In this step I set baud rate to 19205 and data set to 4
Then Adjust > General Setup > Communications > Set Custom Data Sets
Add items and channels to custom set 1.
Do you have any suggestions? Thanks again.
