motec m400 electronic throttle adjust table
PostPosted: Tue Jul 11, 2017 12:51 pm
by Caroline
I active motec m400 drive by wire option, I want to use it to control electronic throttle.
However, this is my first time to use this option. what puzzles me is the adjustment of parameter and table.
Expect a reference table. Thanks a lot. :cry:
Re: motec m400 electronic throttle adjust table
PostPosted: Tue Jul 11, 2017 6:12 pm
Please find the attached DBW setup notes.
DAD0001 Drive by Wire_Electronic Throttle Setup.pdf
(318.48 KiB) Downloaded 1832 times
PostPosted: Wed Jul 19, 2017 9:31 pm
by JulianEdgar
Thanks very much for this Stephen.
PostPosted: Tue Dec 12, 2017 8:27 am
by MarkMc
Just be aware that document does not cover the settings of the PID, feed forward, etc. It is best to send us the part number of the throttle you wish to use and we can provide you with the correct settings. If we have not done a particular throttle you can send it in and I can get a set up for you. The calibration of the throttle is a little involved and needs to be done correctly.
PostPosted: Mon Jul 09, 2018 1:06 am
by Tunedgether
I need DBW setup data for Honda Brio (L12 Engine). Part Number GMD4D T12000020384.
Regards,
Paisan R.
PostPosted: Mon Jul 09, 2018 10:01 am
Hi Paisan,
We have not done this throttle body, are you able to organise to send it to us through your local authorised MoTeC dealer for calibration?
PostPosted: Mon Jul 09, 2018 5:14 pm
by Tunedgether
Thank you for reply.
I am in Thailand.
How can I contact a dealer?
Regards,
PostPosted: Mon Jul 09, 2018 6:19 pm
This is the details for our dealer in Thailand.
https://www.motec.com.au/dealers/dealersasia/#Thailand
PostPosted: Mon Jul 09, 2018 7:34 pm
by Tunedgether
Can I send throttle body direct to you? I think that's a faster way.
