Diff oil cooler and pump
M800 ecu
Ive fitted a oil cooler and electric oil pump to a diff.
there is a temp sensor on it connected to AV5 and is functioning and being logged be the ECU
I would like to control the pump from one of the outputs using the temperature from the sensor.
the sensor is setup as a user input on AV5 and called "Diff Pump"
in the Parameters of the outputs i can't find any way to associate the AV5 to it.
Is it possible to do what im trying to do or another way?
