Feature Request
Feature Request
Postby pnanassy on Sun Jan 25, 2009 11:04 am
im not sure if it has been covered before (if so, im sorry).
RPM dependant Oil pressure warning.
Fuel pressure vs MAP warning.
Thanks,
Peter
pnanassy
Re: Feature Request
Postby Dragon on Sun Jan 25, 2009 1:43 pm
You can do these by using Aux Tables, if you have any spare outputs.
Dragon
Re: Feature Request
Postby pnanassy on Sun Jan 25, 2009 6:09 pm
Sure,but integrating these usefull features into the sensor setup would be great,so that way the driver warning would be activated.Also im out of outputs already...
pnanassy
Re: Feature Request
Postby Wolf_Tm250 on Fri Feb 20, 2009 12:09 am
pnanassy wrote:Hi,
Yes, VERY interested in these features too !
Thanks.
Wolf_Tm
Parma - Italy
Wolf_Tm250
Re: Feature Request
Postby pnanassy on Mon Feb 23, 2009 7:39 pm
I solved the Fuel pressure vs MAP by using a differential fuel pressure sensor.
pnanassy
Re: Feature Request
Postby Wolf_Tm250 on Mon Feb 23, 2009 9:26 pm
pnanassy wrote:I solved the Fuel pressure vs MAP by using a differential fuel pressure sensor.
Yes... I know this is A solution.... but I already have 1 fuel pressure and 1 MAP pressure:
why add another sensor ( plus its wires and pipes ) when it would be an easy calculation for the ECU software ? ;)
Please add this feature! Thanks in advance. :)
Wolf_Tm
Parma - Italy
Wolf_Tm250
