M880 pin#27 (0 v )
I am installing a M880 and have found the 0v pin #27 seems to have an internal problem,If I use the #11 or #13 0v pins I have proper readings on my sensors. Is this something that needs to be looked into or can I just wire to the other 0v options and not worry about this issue. Thank you for your input
