M880 pin#27 (0 v )
M880 pin#27 (0 v )
Postby RickD on Wed May 17, 2017 1:32 pm
I am installing a M880 and have found the 0v pin #27 seems to have an internal problem,If I use the #11 or #13 0v pins I have proper readings on my sensors. Is this something that needs to be looked into or can I just wire to the other 0v options and not worry about this issue. Thank you for your input
RickD
Re: M880 pin#27 (0 v )
Postby SprinterTRD on Wed May 17, 2017 2:13 pm
You have probably shorted +12V to the pin somehow damaging the pin.
Best return it to a MoTeC Dealer for repair.
Do not use 0V Pin 13 for any sensor it is only used for RS232 comms.
Postby RickD on Thu May 18, 2017 2:28 am
Thank you for the info
RickD
