Injector cut on decell
Fri Apr 21, 2017 10:02 pm
by CPL Racing
Is it possible to close the fuel injectors fully on decell?
Re: Injector cut on decell
Sun Apr 23, 2017 8:10 am
Adjust->Functions->Overrun Fuel Cut is where you configure that.
Did you see the note in the help that overrun fuel cut won't be active if the Engine Temp is less than 50 degC (122degF)?
Mon Apr 24, 2017 7:03 pm
by JulianEdgar
Are you looking at the fact that it still shows a small injector duty cycle even when the injector cut is on? I don't know of a way of getting rid of that, and I am not sure why it is there.
Tue Apr 25, 2017 2:48 am
by CPL Racing
Hi guys,
Thanks for the replies
I do have the injector cut active, it now matter how I set the parameters the injectors not not shut fully. Also after a period the injector pulse width increases and is accompanied by loud banging in the exhaust.
Tue Apr 25, 2017 5:58 pm
by CPL Racing
Below is a screenshot showing the problem
Tue Apr 25, 2017 10:40 pm
by Russ
Whats your idle activate rpm set at?
Tue Apr 25, 2017 11:27 pm
by CPL Racing
Hi russ
Idle activate rpm is set to 1800
I don't have an idle valve, I have itbs with the idle controlled with ign comp.
Is the injector pulse modified on return to idle ?
Tue Apr 25, 2017 11:52 pm
by Russ
Hello
Could be wrong but suspect overrun fuel cut will turn off when rpm drops back into idle area.
Wed Apr 26, 2017 12:28 am
by CPL Racing
Thanks I'll try lowering the rpm
Wed Apr 26, 2017 12:50 am
Any chance your Injector Battery compensation is 840 uSec at that voltage/pressure? You are looking at actual pulse width, (not effective pulse width) and I would expect the the injector dead times would be included in this pulse width.
