DUCATI 48-2 mode 60 flywheel
Tue Apr 18, 2017 7:54 pm
by DGMmoteur
I'm trying to do the initial setup of this engine, someone has the required wiring for this special trigger mode ?
Is it necessary to connect the sync pin to the ref pin ?
Thank you !
Re: DUCATI 48-2 mode 60 flywheel
Wed Apr 19, 2017 9:14 am
by Auto Sport Elect
Yes you join connect the crank sensor to both Ref and Sync.
They are not the easiest engines to get to sync up, especially if they have a lot of light weight components in the rotating assembly.
Sat Apr 22, 2017 12:46 am
by DGMmoteur
Hi !
Thank you for the answer. We have tried several enhancement : make deeper teeths (that's working quite fine), and we have put a hall effect sensor.
Thu Sep 21, 2017 3:43 pm
by Auto Sport Elect
Good to hear.
Best upgrade you can make is going to an M1, they start better than a road bike.
The difference on the same bike from a M800 to and M1 is bigger than I can describe. Well worth the investment.
