M800 enabled options
Postby mr2daj on Thu Mar 23, 2017 4:06 am
Hi, Is there any way to tell which options are enabled on my m800 such as lambda and traction control? Ideally from a saved tune but I can plug into the car if needs be.
Thanks, Dan
mr2daj
Re: M800 enabled options
Postby David Ferguson on Thu Mar 23, 2017 5:58 am
ECU Enables are shown on the left side of the ECU Manager window when you are connected to an ECU.
If your saved configuration is using Lambda Control, or has Traction Control enabled it's likely that the ECU has been enabled for those features.
