M800 ERROR injector OPEN
I am having a problem on a Chev LS7 running the standard high impedance injectors. We are seeing random diagnostic errors on the F3 screen. On startup we can see say from cold a few injectors (it is running full sequential) trigger an "error inj 4 combinded Open" ie it goes red and rather than ok saids "open"
I have conducted the following checks: (results below)
- Resistance test from Injector pin to ECU Pin, do this one more than one injector to have a proper base line all went to 0 on ohm meter)
- Resistance test from the 12V+ source to the injectors, do this one more than one injector to have a proper base line. All47.8 ohm
- Resistance test the injectors (probably not needed as you have swapped the injectors around) all 13.4ohm
- Resistance test between the ECU injector pins and ECU Ground All 104.4 ohn
All appeared good on the tests above and I used contact cleaner on all injectors plugs etc.
This error is often isolated to inj4 but others will pop up. I swapped inj 2 and 4 but the error persists on 4 and I haven't seen it on 2.
You can see on this youtube clip what I am talking about when I recorded a short portion
https://www.youtube.com/watch?v=WUJ2Z0dXgog
First time I started today I had a collection of errors on different injectors that cleared quickly. Inj 4 persisted but as that video shows it will clear. At times inj 5 will flash up as well. I had a close look at plugs but I dont think they are an issue. With more rpm on say 2000 odd you tend not to see errors. Also as the idle drops down and it wants to stall out but is still running you will see more of the injectots come up open.
I am hoping this is a setting in ECU manager that I maybe need to adjust. We have run the car at pace on the track and there is no apparent miss but would be good to understand and correct this.
Any ideas much appreciated.
I have injector current set to 0 as I understand thats where it should be for injectors in the 12 to 16 ohm range.
