M600 ref problem
Hi,im currently in the process of swapping the ecu in my Torana to a M600. The motor is an RB30 and I'm using an aftermarket crank trigger setup that uses a 12 tooth 1 missing wheel with a hall sensor. Im also using the home signal that comes with the kit, its made for a twin cam RB but I have fabricated a braket to suit the single cam. It all seemed to be working fine,i did a couple of ref/sync captures
Then while I was cranking the motor trying to check the crip I noticed the rpm on the screen drop to zero, up until this point it was sitting consistently on 190rpm while the engine was cranking. So I did another capture and both the ref and sync just showed a straight line at 6 volts on the capture. I swapped both the hall sensors out for brand new unused spares I have,now I'm getting a sync signal but still no ref
ive checked the power and earth wires on the ref and sync wires and they seem ok,have 8 volts at the plug.im not sure how to test the signal wire. So I don't really know where to go from here.
here is a couple of pics of the triggers and how I have it set in the ecu also,any help from here would be greatly appreciated
