Paddle shift M400 Downshift
I'm trying to setup a pneumatic quick shift system for the DIT Formula Student team.
I'm using an M400 ECU with a wr450 single cylinder engine.
The upshift works fine but when I use the down shift paddle nothing happens. However it works when I hard wire the pneumatic system directly to the Paddles. Also the ECU is receiving the Downshift request signal.
So it's not failing on a Mechanical and Electronic aspect. It must be an ECU issue.
This is the way I have it setup:
GEAR IGNITION CUT
CUT MODE : 2 (DELAY FROM CUT SIGNAL)
CUT SOURCE : 6 (GEAR SHIFT FUNCTION)
MIN RPM : 1500
MIN THROTTLE POS: 5
ARM DELAY: 300
GEAR SHIFT
MODE : 1 (USE DIGITAL INPUTS)
ARM DELAY : 350
DOWN SHIFT
DOWN MAXIMUM RPM : 10500
DOWN MAXIMUM THROTTLE : 60
DOWN OUTPUT DURATION : 120
AUTOMATIC DOWN SHIFT : 1
Also I'm using this without a gear position sensor, since the gearbox was modified to have N as the front gear.
I have played around in the ignition cut function, with no succes.
Any Ideas how I could make this work?
GEAR IGNITION CUT
MIN RPM : 1500
MIN THROTTLE POS: 5
ARM DELAY: 300
GEAR SHIFT
ARM DELAY : 350
DOWN SHIFT
