Custon Firmware
Custon Firmware
Postby sphilips on Mon Jan 09, 2017 6:49 am
Anybody know if it is possible to get a custom made firmware for the m800?
For example, to use an AV as an AT input (if possible within the unit)
Or an extra digital input to use as an on/off button for something
Or making a function for engine brake instead of nitrous
sphilips
Re: Custon Firmware
Postby Stephen Dean on Mon Jan 09, 2017 8:44 am
You can make an AV into an AT by adding an external 1k ohm pull-up resistor between the 5V and Signal wires.
Are you wanting another Dig input on top of the existing 4? You can use the AT inputs as switches as well.
We have finished development of the Mx00 series ECU's so adding functions will not be possible.
Re: Custon Firmware
Postby sphilips on Tue Jan 10, 2017 7:09 am
I have used al 4 dig inputs and the at inputs, but I'll convert an av to an at. That will do.
It is a shame that there aren't any updates, all I need is some extra aux table and then I'm happy :D :mrgreen:
sphilips
Re: Custon Firmware
Postby sphilips on Tue Jan 10, 2017 7:29 am
I maybe have an idea to have some aux tables, but I have to check it in real life on the bike.
sphilips
Re: Custon Firmware
Postby Sean on Mon Jan 30, 2017 11:29 am
I'm curious now, what are you trying to do?
Sean
Re: Custon Firmware
Postby sphilips on Tue Jan 31, 2017 9:30 am
I want to adjust the engine brake and traction controle more than now. I am thinking on closed loop engine brake.
sphilips
Re: Custon Firmware
Postby Sean on Tue Jan 31, 2017 10:19 am
Interesting....... What bike?
Sean
Re: Custon Firmware
Postby sphilips on Tue Jan 31, 2017 5:29 pm
CBR1000rr SP1 2017, we are going to ride the Fim EWC endurance :D
look at facebook Mototech EWC or twitter #Mototechewc
sphilips
Users browsing this forum: Bing [Bot] and 7 guests
