Barometric Pressure Compensation
I have an M800 OEM with a Baro sensor set up on AV4. I thought that the only setup required to activate the Barometric Pressure Compensation was to have the sensor set up in the input Setup and a standard 1:1 Barometric Compensation would be applied as a trim to the fuel. My Barometric Compensation is reading 0.0 under all conditions. Are there other setup requirements to activate Baro Pressure Comp?
