Unable to Start - M800 & IEX
Hey guys,
I am having issues trying to get my car to start, or even try to.
Base File & SYNC REF Capture Attached
Engine: Ford Windsor 5.0L
Trigger: 36-1 (Missing Tooth is at 90-95*)
Sync: High / Low Level Sensor (Rising Edge @ TDC Compression #1)
Injectors: ID/YP 1000cc (1015cc @ 43.5PSI) (Wired in Firing Order 1-3-7-2-6-5-4-8)
Base Fuel Pressure: 43.5PSI
Motec IEX Module
IGN Mode 100
Coil Count 8
Coil Type: is LS D585
Coils are grounded to the same point as the M800
These have tested out fine (Set IGN Mode to 1, with 1 Coil and jumper lead to each output)
First Issue is trying to work out my CRIP but the engine refuses to fire.
Engine cranks at about 120-150RPM, It is a Heavily Springed Solid Roller Motor w/ 12.5:1 Compression.
My SYNC Sensor never actually comes back down to 0V could this be causing an issue?
I know there is something I am missing and I am ready to rip my hair out.
All Other Sensors work and when cranking the car comes into sync but it seems we don't get enough spark output.
Have tried a variety of CRIP
Also when cranking i have seen the 'INJ DUTY MAX ERR' Occur which is concerning.
95
103
463
563
620
710 - This Bangs out the exhaust
Motec Hardware is:
M800
E888
IEX
C127
Please help, I am at my witts end
Regards,
Nathan
Motec IEX Module
IGN Mode 100
Coil Count 8
95
103
463
563
620
Motec Hardware is:
M800
E888
IEX
C127
Regards,
Nathan
