Extra injector for charge cooling
Hello
I M800 on a subaru using 2 injectors per cylinder running methanol, latest set-up is with-out intercooler and i wish to run an extra injector just after the turbo in the pipework to charge cool.
I have set this extra injector up on Aux1 and i'm trying to find the appropriate out-put type to use....
Aux table seems like the most appropriate but the injector control is very basic, ie you don't have frequency control, which i would like to be tied to rpm like a normal injector, i have set an injector up in a test/cleaning machine and played with pulsing it with the Aux1 output, problem is the control window is very small, with a parameter frequency setting of ~100-150Hz the injectors is either off or on.....it will start pulsing at ~19% and be fully open at ~22%, there is very little useful control, setting the frequency lower and the injector is pretty much wide open on any pulse and any higher frequency and it won't even fire until a high %.
Can anyone suggest a way to do this effectively, i wish to have a table based on RPM and boost so i can feed Methanol in this injector to charge cool.
Cheers
Justin
Cheers
Justin
