Page 1 of 2
Ref/Sync errors, but not on idle
Sun Aug 28, 2016 2:56 am
by Amigo_88
Hello MoTec-Team,
We have an Audi FSI engine (2 litre, modifierd for CNG) running with the M800 on a test rig. At idle, everything seems to be fine, the engine is running nice and smooth. Leaving the idle, ref sync problems occure (3. Errors):
1. Ref Signal
2. Ref Noise Ar
3. Sync Signal.
Missfire happens, and the ref sync capture shows an extended sync pulse (could't upload the fiel, therefore I took a picture).
Ref signal by Hall sensor and gear ring with 60 teeth, sync by Hall sensor and one defined pulse. The ref/sync configurations are also attached.
Hopefully someone can help me. Thanks in advance.
Re: Ref/Sync errors, but not on idle
Sun Aug 28, 2016 4:15 am
by Arve Flaat
Hi
If you use 60 teeths you MUST use a magnetich sensor.
If youhave 4 teeths you can use a hall sensor.
AF
Mon Aug 29, 2016 3:02 am
by Amigo_88
Arve Flaat wrote:Hi
AF
Hello Arve,
do you have any explanation why a hall sensor can't be used ? Thanks.
Regards,
Chris
Mon Aug 29, 2016 5:52 am
by AdamW
Amigo_88 wrote:Arve Flaat wrote:Hi
AF
Hello Arve,
Regards,
Chris
Arve is wrong with this comment. A Hall effect sensor can work perfectly fine with a 60 tooth wheel provided the sensor is designed for it. Many OEM's use this combo. Perhaps he was talking about some of the generic Honeywell or cherry industrial sensors which often aren't fast enough?
Your wave form is quite distorted so that gives the suggestion it is not fast enough. What is your sensor - is it oem and matched for the wheel?
Mon Aug 29, 2016 6:02 am
by Arve Flaat
Hi
The hall sensor is not fast enough.
Works on lo rmp but not hi.
The easiest fix is change to magnetic sensor. Wire it on 0v and signal.
If you use hall sensor you must increase the distance between the teeth's.
I did run a C20XE on 2 teeth's + synk.
AF
Mon Aug 29, 2016 12:00 pm
by stevieturbo
Arve Flaat wrote:Hi
AF
Many engines use a 60-2 wheel and hall sensor.
Tue Aug 30, 2016 5:39 am
by Amigo_88
Arve Flaat wrote:Hi
AF
Hi Arve, I still couldn’t fix the problem. Maybe, a magnetic sensor wouldn't have any problems with the 60 teeth wheel. Can you recommend a magnetic sensor?
Teeth distance: 4 mm
Teeth width: 2.5 mm
I want to try it. Thank you in advance.
Chris
Tue Aug 30, 2016 5:54 am
by stevieturbo
Are you using the OEM sensor and trigger wheel ?
Tue Aug 30, 2016 6:58 am
by Amigo_88
No. I use a SICK Hall sensor that should be capable to deal with the 60 teeth up to 6000 rpm because of 8 kHz, but in fact it doesn't
At 1000 rpm everything works fine, the ref signal has a nice square shape (for both! magnetic and hall configuration in motec ecu). At 1700 rpm the nice shape is gone, triangles appear now as ref signal (in case of hall configuration) and in addition this bad signal even isn't stable e.g. the sensor can't recognize single teeth in some cases so the ref signal stays high while 3 to 6 teeth are passing the sensor (happens for both: hall and magnetic config.).
Wed Aug 31, 2016 9:56 am
by stevieturbo
Why can you not use the OEM trigger wheel and sensor then ? Surely that would be easiest and most reliable option ?
