May interest some - 23.5:1 AFR
Postby JulianEdgar on Sat Aug 20, 2016 8:56 pm
Hi everyone. I have an original Honda Insight. Not running it as a hybrid, but with turbo and water/air intercooler. M400 plus ADL3 plus expander box. Bigger injectors, new Bosch coils, new airbox, etc. Control boost, EGR, VTEC, etc.
Lean cruise is the exciting bit - has taken a s**load of work to get it perfectly driveable.
Current approach is that lean cruise mode needs:
- Engine temp above 80 degrees C for 5 seconds, AND
- Gear equal or greater than 3*, AND
- Manifold pressure less than 120 kPa (ie less than about 3 psi boost) for 0.1 seconds, AND
- Engine RPM greater than 1100 rpm for 0.1 seconds, AND
- Engine oil temp greater than 60 degrees C, AND
- Throttle position greater than 5 percent for 0.6 seconds, AND
- Throttle position less than 85 per cent for 1.0 seconds.
* For fun I brought this down to 1 (ie in lean cruise in all gears when other conditions are met) and I actually got it to drive very well. Found it to be a good test - if it drove well in gears 1,2,3,4,5 then there would definitely be no problems in 4th and 5th.
Then lean cruise mode =
Pretty exciting numbers!
JulianEdgar
Re: May interest some - 23.5:1 AFR
Postby Rude Engineering on Fri Nov 11, 2016 5:45 am
Interesting... What are the Lambda values when this is functioning? And have you done any exhaust gas analysis on this?
Ross Buckingham
Rude Engineering Ltd. Racing Engine Technology. Hampshire, U.K.
Rude Engineering
Postby JulianEdgar on Fri Nov 11, 2016 7:16 am
Air/fuel ratios are as lean as 23.5:1 (lambda = 1.6) when in lean cruise. I have not done any exhaust gas analysis.
JulianEdgar
Users browsing this forum: Bing [Bot] and 25 guests
