Single Cylinder Setup
Hi guys,
Been having a lot of issues of late with moving to a Motec M400 ECU.
I have a 2004 KTM 525 EXC engine that is being used in a single seater racecar. I have made a custom 12-1 trigger wheel to attach to the flywheel and getting a very clean reference signal with a magnetic sensor.
The issue I am having is getting the engine to run again, and the issues is I do not know what configuration to into the ref/sync setup. I don't have a sync signal that is reliable so was hoping to run with just a ref.
Any suggestions would be incredibly helpful.
Cheers David
Cheers David
