Used fuel measurment
Postby Mazi on Wed Jan 07, 2009 8:43 am
Can't find info about resolution and span. Also if Fuel Used Cal is 0 (seconds of injector...)
Mazi
Re: Used fuel measurment
Postby MarkMc on Wed Jan 07, 2009 2:58 pm
Hello Mazi,
The resolution is to 2 decimal places for both the fuel used and fuel injector time. For the fuel used if you set the parameter as total CC per minute you get the display in liters (with the two decimal places). For the time you get it in seconds with 2 decimal places.
The ECU Manager software only shows the channel to one decimal place but it is two decimal places in the logging.
The maximum value for the channel (fuel or seconds) is 327.68. Once you go over this, if you ever do, you will find the channel rolls over to -327.68 and continue to count up, this is because it is a signed 16bit number.
Postby Ben-S on Wed Jan 07, 2009 3:50 pm
on the same topic is there a way to get the fuel used to remain counting after the ecu is reset?
Ben-S
Postby MarkMc on Thu Jan 08, 2009 10:59 am
Hi Ben,
Unfortunately no, the ADL is the only way to do this.
Users browsing this forum: No registered users and 39 guests
