How to define User Defines Digital Input Switch
Postby IamTheStig on Mon Jul 11, 2016 4:04 am
I'm using a M800 ECU and want to use the value of a switch as an axis for a map. I tried different configurations and never succeded. Can you please show me how to configure the switch in the Digital Input Function and Input Setup?
PS: I wired the switch to ground and it's working fine in that configuration on that input, if I use it as TC Disable Switch.
Kind Regards,
IamTheStig
Re: How to define User Defines Digital Input Switch
Postby Stephen Dean on Mon Jul 11, 2016 1:14 pm
Can you give some more details about what you are aiming for with the switch, and what you are using to do it.
