Motec M400 on K20a2 with DBW
Postby EP3M400 on Sat Jul 09, 2016 8:38 am
Hello guys,
Looking for a bit information.
We have a Honda Civic Type R K20a2 with Quaife Sequential and we've just purchased a M400 ECU. The car currently has the following modifications:
Toda A3 Camshafts
Toda A3 Valve springs
Toda Manifold
3" Exhaust
RRC Inlet Manifold
70MM Cable Driven TB
RDX 410CC Injectors
Tilton Pedal Box
The M400 was previously fitted to a Rotrex K20a2 with a Sadev Sequential which used the stock engine loom and sensors meaning our loom will plug straight into the M400 bar wiring in our load cell from the sequnetial.
We want to run DBW off a FD2 Civic Type R.
Does anyone have information on settings for the DBW? And where the wires from the pedal potentiometer / TB are best wired too?
And secondly does anyone have a calibration that will get us up and running?
Thanks for your time and help in advance!
EP3M400
Re: Motec M400 on K20a2 with DBW
Postby Stephen Dean on Mon Jul 11, 2016 1:15 pm
If you have the part number for the DBW I can have a look in our calibrations and see if we have done that one.
