Gear Ratio data problem
Hi guys,
Hoping I can get some insight on this issue, also posted under i2 forum since i'm not sure if its related to ECU or i2.
Ive set my gear ratio values in my ecu, but the data is not coming into i2 when I open my logs for analysis. Its causing problems with my clutch slip analysis.
More info in my earlier post/.
viewtopic.php?f=26&t=3314
Any help is greatly appreciated.
Mike -
Mike -
