M800 Using Older V2.20 and Upgrading Queries
I've been asked to tune a Subaru with a M800, but the ECU is running older firmware (V2.20). The software I have is V3.52P. The car drives very well so I would really like to save a backup of the map prior to upgrading the firmware, and as such I have a few questions?
1. Is the upgrade from V2.20 to V3.52P a seamless upgrade?
2. If not, does anyone have, or can point me to, a list of calibration checks or changes required after the upgrade?
3. Does anyone have a copy of the v2.20 software, or will V2.20F2 (available on MoTEC site) work? I can install this on a secondary laptop just to save the map prior to the firmware upgrade if needed.
4. The system has a parallel port comms cable, which seems to work with the V3.52P software, as the pop up stating the firmware needs to be upgraded came up. I am 99% sure the answer is yes, but would just like to know for sure if the parallel comms cable will work well with V3.52P.
5. As this is an older model, and is working well, are there any major advantages to upgrading the firmware from V2.20 to V3.52P?
6. Can the USB comms cable work with V2.20? (The secondary laptop won't have a parallel port).
Thanks for any help.
