M800 - Ford 5.0L Windsor Setup
hey guys,
I was wondering if i could get a second pair of eyes over my proposed setup for my Street / Strip car.
Engine:
364 Cube Ford Windsor
Estimated RPM 7800-8200RPM
Fuel Injectors are Injector Dynamics ID1000 Items, so i don't think there needs to be anything more spoken about them
Engine has a Sheet Metal tunnel ram which will be topped with 2x Holley 112-587 Throttle Bodies with inbuilt GM IAT, GM TPS & GM/Chrysler IAC Valve.
Now,
I have an M800, E888 and soon a c127 Dash.
I have Advanced Functions unlocked in my ECU and will be getting the licencing for Dual wideband support.
First Question:
Is it Possible and Recommended to run a GM Ethanol Sensor to allow on the fly switching of fuel in the car?
Second Question:
Current Setup (as run on a Haltech ECU... )
Motronic 36-1 Crank Wheel (Missing Tooth is roughly setup at about 28-30 BTDC) This is adjustable so Would be recommended or should I move the wheel so it occurs at a different point in the cycle as well as correctly setting the ECU to have the window occur twice in a Cycle.
Cam Sensor is currently a 2 Wire Sensor, I can easily change this out for a 3 wire Hall Effect s due to the 150RPM cranking speeds, we expereinced missed counters during cranking.
Crank Sensor is also a 2 Wire reluctor Sensor, If required I can fabricate a new mount and install a hall effect sensor which would be preferred?
Third Question:
I wish to use Traction Control in the ECU,
Since I am completely ditching the factory ECU in my Car ('99 Ford Fairlane), My ABS Module will not function correctly if at all. Could I feed the ABS Wheel sensors into the E888? or are there specific sensors which need to be used?
Fourth Question:
Dual TPS / Dual IAC,
Since each of the throttle Bodies will have an IAT, IAC and TPS.
Could these be used together? or even just for calibration purposes to ensure the butterflys are correctly insync with each other? Since it has a decent size camshaft can the Motec work both idle Solenoids as not to cause a mixture imbalance from the front four and rear four cylinders or am I looking too far into it?
Fifth Question:
I also have an IEX Module I will be running along side the M800 & E888 for Sequential Ignition.
I Understand Waste Spark will work as well but I prefer to have only a single spark plug fire for each cylinder to minimise igniting any left over charge from the nitrous use in the cylinders to prevent a backfire.
The coils I am running are Denso D585 LS Truck coils, I understand there were issus with the IEX Modules and these coils discharging during cranking due to increased Dwell times. I have read that there is a modification that can be completed? or is it a tune related item?
Sixth Question:
Crankcase pressure.
This is something I would like to monitor/log especially under Nitrous use.
What Sensor is recommend and position for a reading?
along side this I have been looking into a Vacuum pump for the engine so I understand too close to the vac source in the rocker covers might be a false reading, and too close to the actual combustion process in the oil pan could do the same.
Would the Lifter Valley at the base of the intake manifold work?
Seventh Question:
This will be the last question for this post as I have plenty more just so i can make sure I get this setup correct before it heads off to my tuner.
EGT Sensors, This is the reason I am running the E888 Expander.
I would like to Monitor and run protection schemes for nitrous use.
Is it possible to program a failure mode, for example if a misfire is detected that the nitrous and nitrous fuel supply is cut off from supplying the engine any more and flash the cylinder on the dash? I believe I might need to obtain the display creator licence for this?
Thanks in advance and Apologies for sounding like an uneducated person in this pursuit.
Regards,
Nathan
Engine:
Now,
First Question:
Second Question:
Third Question:
Fourth Question:
Fifth Question:
Sixth Question:
Crankcase pressure.
Seventh Question:
Regards,
Nathan
